Hi, bin a few years since I built my PC, A huge accumulation of dust, very poor temps for a while now, and suddenly a few days ago a large bubble appearing in my loop have lead me prepare for a long overdue refurbishment this weekend.
Here is how my fans are laid out: https://ibb.co/iGLcr7
And the current direction of airflow: https://ibb.co/hfQz4S
I think I may have misunderstood the direction of the air flowing through my fans when I did my build. At the moment warmer air from inside the case (presumably warmer?) over the radiators, it makes more sense to me to have cooler air flowing from outside the case over the radiators??
I took the side of my case recently and the average temps seemed to go down a few degrees which seems to back this idea up.
Or perhaps I should have one radiator going in and the other out, or any other configuration?
I have just bought some new fans (upgraded from Corsair SP120's Quiet edition to performance edition) - I wanted to check something about the fan type - I understand the SP fans are better against the resistance caused by the radiators. With my larger radiator having fans on both sides would it be better to have one side with SP fans pushing against it and AF fans drawing away from it on the other side?? Perhaps a stupid idea.
A final question - I bought my rampage iv extreme motherboard from a friend with water blocks installed on everything. I now understand that cooling ram (Corsair Dominator GT 4x4gb)) is pretty pointless - Does anyone know if I will get a decent temperature drop if I omit them from the loop? Worth bearing in mind that a) I don't have the passive cooling strips that sit on top of the ram to put back on and b) all my pipes are hand-bent acrylic and the thought of having to bend some new pipes to miss out the ram out gives me a headache.
Any help much appreciated and thanks
