- 27 Apr 2014
Does Rise of the Tomb Raider need a reshade file no it does not the game looks stunning in most areas.
I just wanted to make things brighter in the sky and a little darker on the ground for the PC
I done up some HDR files for playing DX11 Games(64Bit/32Bit Files) ..
Rise of the Tomb Raider Geothermal Valley running around checking out the sites.
Install-
Just extract the files and put them in your game folder where executable for the game is Installed on PC.
Toggle-
To turn it on and off just press Delete button.
Take Screenshots-
You can take screenshots by pressing Print Screen .It is set to .PNG files.
Is FPS affected of course it is10-20 FPS.
Thanks/Credit go to the Makers of Reshade/SweetFX.
Download-
http://www.mediafire.com/download/1e3v5b6s9b3a46l/64bit-32bit+Reshade.7z
Added screens.With youtube the compression its hard to tell what changed.
Install-
Toggle-
Take Screenshots-
Download-
