what socket is it?
nvm just looked into it, its a 1366 ocuk only have 2 1366 board, 139 and 159
OcUK have b grade boards the same one you have.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-506-AS&groupid=595&catid=689&subcat=
by the way, how reliable are B-grade stuff? Do we get a description as to what was wrong with the item?
Right i bought the B-grade version of the same board, installed and everything, the memory problem is gone so i guess the bent pins were the cause. Now a new problem,
No sound from the back audio panel. I have tried using the realtek software manager in windows to see what is happening and normally as soon as i plug in something the menu shows which audio output is active. But that is not the case, all audio ports in the menu are greyed out.
Could this be due to the fact the board was B-grade and it slipped out without getting fixed?
