Roald Dahl
9 Aug 2004
Milton Keynes
Has anyone got any suggestions on where to buy Roald Dahl books. Looking to get some to read to the young ones etc. Looked at waterstones and they are ~£5 each upwards.
Does anyone know of anywhere a little cheaper? I don't mind spending £5 each as they are worth it but if you can get cheaper why not!
Thinking of some cheap ones off amazon marketplace but not sure! Also not keen on Ebay unless someone can suggest an actual decent seller?
When you're only talking a couple of quid, what's wrong with ebay? I also suspect there's a high correlation between "people who sell Roald Dahl books" and "decent people".
Amazon is good for getting good deals.
Have you tried a local book shop?
Yep however most of the proper local ones are either rubbish price wish or shut down due to low demand from Internet/waterstones :(
Then looking at charity places they want basically want amazon prices for 2nd hand books
I guess its just I never used it and couple of mates got screwed and then all the talk on here makes me think its not worth it tbh!
I won't suggest a place to buy, but if you're looking at Roald Dahl, check out his short stories too (Tales of the Unexpected) - they're an easy read, good for train journeys and holidays.
I got a hardback copy of the collected short stories of Roald Dahl for £5 or £6 inc p&p from ebay a while back. I prefer them to his kids books. Fantastic stories, though some (though by no means all of them) are a bit mature for small kids (I assume they're for the two in your sig?).
If you're after his kids stories I'd suggest hunting around for some on amazon, either get over £15 worth from amazon for free postage on the megadeal thingy, or hunt for some dirt cheap ones in the marketplace. You'll probably be able to pick them up for under a quid plus £2.75 p&p each in good to excellent condition. Alternatively go for ebay - I doubt anyone is going to try and scam you for a quid or two, especially if they're the sort to be selling kids books.
