- 10 Aug 2009
- Banbridge, N.Ire
Came home to find my router flashing orange lastnight and having problems getting it back to normal.
My ISP is Sky and I use a Belkin N600 with the hacked settings, but it seemed to reset itself. The SSID and all the other settings were back to factory.
I have managed to get most of the settings restored and can connect to the internet wired, and the wifi seems to be working, but when I disconnect the ethernet cable the wifi doesn't work.
If I then re-connect the cable I can get access again. it also seems to be running a bit volatile, second or third tabs dont seem to load properly either.
Any help greatly appreciated.
