So, My Ryzen 1600 is annoying the living hell out of me and am not entirely sure whats causing it.
So, I can't run the latest bios in MSI for my 350m due to it failing 3dmarks timing issues, So am stuck using 1.5v which has a overclocking bug causing the cpu to lock to 1.5ghz if you touch cpu voltage, Fixed in 1.6 but as I said, 1.6 does strange things to my computers timings.
In BF1, My FPS ranges from 70-120fps, That range is huge. I have a 1080ti so its not like am lacking raw power. CPU doesnt seem to be bottlenecked too, Nor GPU. There both just in limbo around 60-70%.
I also get insanely low FPS in Garrys mod, though being a old source engine I can sort of understand but I get lows of 40 fps in somemaps where people with 970s and 4000 series cpus get triple my fps.
Witcher 3 will run around 100 fps but again I do drop to like 90 fps someplaces where benchmarks say I should avg around 140fps.
This is all at 1080p, I assume that even though my CPU inst showing 100% usage its bottlenecking my gpu in every single game I play heavily, Causing insanely low fps drops.
Not sure what to do, Maybe it is a bug, Anyone shed some light.
