Samsung 2693HM 26" Monitor
24 Aug 2006
Cardiff
Has anyone had any handons experience with the, I assume new Samsung 2693HM 26" inch Monitor it retails for around £420 and I'm very tempted as the Dell 27" is out of my price range but I can't find any reviews on the Samsung panel.
It will be used mostly for gaming and my eyesights not brilliant so needs to be a resonably sharp clear image.
http://image.******.com/UK/P0141323_C0000012_P0000000.jpg
Specifications
Display
Screen size 25.5"
Brightness 400cd
Contrast Ratio DC3000:1(1000:1)
Resolution 1920 x 1200
Response Time 5ms
Viewing Angle(H/V) 160 / 160(CR>10)
Color Supported 16.7M
Signal Input
Video Signal D-sub, DVI, HDMI
Sync. Signal Separate, Composite
Connector D-sub, DVI, HDMI
That's a thought, never bother to check what the viewing angle is on my new 2707
dell ! BTW don't waist your money on the Samsung get the Dell 2707wfp, I upgraded from a Viewsonic 201 to this wow everything is just much better.
