SAMSUNG PVA MONITOR REDUCTIONS
Status
Not open for further replies.
17 Oct 2002
Stoke
We've got some absolutely awesome pricing on Samsung's range of PVA monitors. As most of you know, they offer better viewing angles than TN and the colours are far superior.
Samsung F2080 20" Widescreen LCD Monitor @ £156.99 inc VAT
The Samsung F2080 20" 16:9 widescreen LCD display features cPVA panel technology for accurate professional-caliber colours. With 100% support of sRGB colour mode and 178º viewing angles, the colour will be smooth and accurate to everyone gathered around your screen. High 150,000:1 contrast ratio provides subtle transitions in shadows, and details in the whites and blacks. The 2.5mm bezel-to-screen depth and the 15mm ultra-narrow bezel combine to give you an even, virtually seamless display area when tiling multiple displays. And the Tilt / Swivel / Pivot / 130 mm height-adjustable stands also add comfort.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 150000:1
- Brightness: 300cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 2x DVI-D
- VESA Compliant
- Adjustable Stand
- Dimensions: 474.1mm x 357.6mm x 197.0mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
Only £156.99 inc VAT.
ORDER NOW
Samsung F2380 23" Widescreen LCD Monitor @ £199.99 inc VAT
The Samsung F2380 23" 16:9 widescreen LCD display features cPVA panel technology for accurate professional-caliber colours. With 100% support of sRGB colour mode and 178º viewing angles, the colour will be smooth and accurate to everyone gathered around your screen. High 150,000:1 contrast ratio provides subtle transitions in shadows, and details in the whites and blacks. The 2.5mm bezel-to-screen depth and the 15mm ultra-narrow bezel combine to give you an even, virtually seamless display area when tiling multiple displays. And the Tilt / Swivel / Pivot / 130 mm height-adjustable stands also add comfort.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- VESA Compliant
- Adjustable Stand
- Dimensions: 545mm x 476.5mm x 216mm
- Weight: 6.3kg
Only £199.99 inc VAT.
ORDER NOW
I'm seriously tempted by the 23" but I'm concerned as PCPro say it's not great for games and movies. I wont be using it for Movies but will be wanting to play on it.
Compared to say the 2233RZ:
How well do these handle FPS gaming?
You do realize this thread is over a year old, and the products are no longer available? dont worry only another 248 posts till free shipping.:p
Status
