Hi there,
I have a Samsung S27B970D and have just bought a i1 Display pro (which is meant to be compatible). The i1 Display pro works fine with the X-rite software fine but I really want to use Samsungs Natural Color Expert to calibrate my screen.
Every time I try to open up Natural Color Expert it keeps giving me a message 'Monitor is not compatible with NCE'
I have the i1 plugged into one of the usb ports on the monitor as it says in the manual and I have installed the latest NCE software 3.0.1.0. and I'm running windows 8.1 pro.
Can someone give me some tips on how to get NCE working (Badass where are you?!)
Starting to get a bit frustrating!
