Samsung UE32H6400 Wall Mount Screws?
15 Feb 2008
Hi,
Just wondering if anyone has mounted the H6400 series tv on the wall? ... I have a bracket from my old tv which fits but the screws are way to small to fasten the bracket to the tv itself. (m4 35mm)
The usermanual says m4 screws will fit but they don't.
Any ideas cheers.
sure is mate, got the manual in front of me.
will pop out tomorrow and grab some m6/8 screws.
32" - Vesa 100 x 100 - M4 - 43-45 mm
40"+ - Vesa 200 x 200 - M8 - 43-45 mm
