For all the haters!
SB has only been on sale for a couple of weeks, this is a snippet from someone who was testing SB seven weeks prior it's release.
BCLK Overclocking will not murder your CPU or motherboard. There is absolutely no evidence to support the rumours that adjusting the BCLK upwards on a locked or unlocked CPU will kill/damage it. What will happen, is that the system will become unstable, and you will lose control of things like your hard drive or graphics card, resulting in instability, corruption or the inability to start up properly. As with any overclocking induced instability, simply reduce the overclock and you will find that normality resumes - If you have suffered a SATA problem, then you may have to run your Windows repair console to get the boot loader back.
One thing that I would like to mention, and it has been the source of much debate accross many forums over the last couple of weeks, and that is the subject of safe voltages. The short answer is that there are no 100% safe voltages over and above stock, yes there are recommended limits, but as we are driving our CPU way past the speeds at which they are designed to run, then we need to be aware that there can be failures, there can be degradation in things like memory controllers too, but the main thing to keep in mind, is that Intel are keen to push the overclocking side of their K series processors, and for them to do that, they need to offer some kind of warranty. To offer a warranty, they need to bring a product that is robust and can handle a fair amount of abuse, from what I can gather from around seven weeks of testing (at the time of writing this), they have done just that, my CPU has been subjected to well over 1.7v, it has been up to the 57 multi, although it struggled to get into windows, it has been up to 110 BCLK and has had 1.6v on both the VCCIO and VCCSA, and is still able to run LinX at 5200MHz with the memory at 1866MHz 6-7-6-24. In my opinions, the failures that have been reported, and I know of only two that have been confirmed, could easily be down to something as simple as a bad PSU, or motherboard. I guess, what I'm getting at here, is that you are buying a product designed for overclocking, so overclock it, don't worry about it, and enjoy it!
