- 12 Jun 2010
Thanks for the reply. I did however have the problems before I used Driver Sweeper. I only used it as an attempted solution to the problem. I haven't RMA'd the card yet and I'm still not sure whether I should or not. The problems are far too hard to diagnose and I know that they'll just send it back with no fault found. I'll try installing 7 again on my 2nd partition along with the problem games to see if it fixes the issues.
In regard to the triple buffering. I did try GTA4 without Vsync but the tearing was so awful I turned it straight back off again. What annoys me the most about GTA4 wasn't the unstable framerates as GTA4 is never completely smooth, but the terrible aliasingI can't work out why the ATI card looked worse on exactly the same settings. I'll try it again without Vsync again tonight.
This is my first ATI card and I'm starting to regret it nowNot the best introduction to the ATI world.
I wasn`t suggesting running gta 4 with vsync off on a permanant basis i just wanted you to try it to see if your frame rates would hold at anything other than 60,30,20 etc.If you get say 39,40,41,42 etc fps ,that would suggest tripplebuffering is in fact on.If you still get frame rates lurching between 60,30,20,10 then you don`t have it on.
On the subject of anti aliasing i must admit im stumped as i was under the impression nivida and ati cards had no AA on gta 4 at all (except via a mod).I find it strange that you say the aliasing is worse given that both cards would have had no AA.I can only suggest that in CCC you must have a setting thats using a lower quality output.Either that or gta 4 has altered a setting inbetween changeing the cards.This isnt as daft as it sounds cos i`ve had gta change resolution`s on me before now ,not to mention switch off the odd thing or too on it`s own.
It`s one of the strangest games iv`e ever seen for odd behaviour sometimes i see big frames drops ill task out go back in it`s fine,settings changeing themselves like i said before,even periods where it refuses to even load!!!....and then a week later when you try same drivers etc...it loads
.These last few weeks has been the best i`ve seen it running with the 10.10 drivers and with morph AA a lot of the aliasing is diminshed.That reminds me check if the game has activated the in game "blur",that might be why it look so horrible perhaps?
