We have the fantastic Sapphire EDGE HD3 & HD2 mini PC's available for pre-order. ETA is 2 weeks away. We offer the HD2 version both with and without an operating system. We sell the VESA mount separately for the HD3 version as the HD2 comes with a VESA mount as standard.
Sapphire Edge HD3 Mini PC - no operating system @ £259.99 inc VAT
SAPPHIRE EDGE-HD3 is a fully featured PC for home, education or business use. Specifications include a second generation 1.6GHz dual core processor, 4GB of DDR3 memory, a 320GB hard drive and built in wireless connectivity as well as high speed LAN port and four USB ports. It provides high resolution graphics output with a full HD (1920x1080) HDMI interface (with an HDMI cable and HDMI-DVI adapter also supplied) as well as a VGA monitor output and it has built-in audio with mic-in and line-out sockets.
CPU AMD APU E450 1.6GHz
Memory 4 GB DDR3 So-DIMM
Storage 320 GB SATA 2.5'' Hard Driver
Graphics AMD Radeon HD6320
LAN 10/100/1000 Mbps Built-in Etherent
Wireless 802.11b/g/n Built-in Wireless Network
I/O 1 x VGA(D-sub) Port
1 x HDMI Port
1 x RJ-45 Gigabit Lan
2 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
Power 65 W AC 100~240V 50/60Hz, 19v~3.42A
Dimensions 19.3 x 14.8 x 2.2 cm cm (L / W / H)
Weight 530 g net weight
Operation System Pre-installed Free DOS
Accessory 1 x HDMI cable
1 x HDMI to DVI adapter
1 x Quick Install guide (QIG)
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
CD Driver
Only £259.99 inc VAT.
ORDER NOW
Sapphire Edge HD2 Mini PC - no operating system @ £249.98 inc VAT
SAPPHIRE EDGE-HD2 is a fully featured PC for home, education or business use. Specifications include a second generation 1.8GHz dual core processor, 2GB of DDR3 memory, a 320GB hard drive and built in wireless connectivity as well as high speed LAN port and four USB ports. It provides high resolution graphics output with a full HD (1920x1080) HDMI interface (with an HDMI cable and HDMI-DVI adapter also supplied) as well as a VGA monitor output and it has built-in audio with mic-in and line-out sockets.
CPU Intel® Atom™ D525 1.8GHz
1024 KB CPU Cache
Memory 2048 MB DDR3-800 So-DIMM
Graphics 512 MB NVIDIA® ION™ 2
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
Dimensions 19.3 x 14.8 x 2.2 cm (L / W / H)
Support Windows® 7 / Vista / XP
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
CD Driver
Only £249.98 inc VAT.
ORDER NOW
Sapphire Edge HD2 Mini PC - Windows 7 Ultimate @ £319.99 inc VAT
1024 KB CPU Cache
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
Operation System Windows® 7 Ultimate
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
1 x VESA Mount (100mm x 100mm)
CD Driver
Only £319.99 inc VAT.
ORDER NOW
Sapphire VESA Mount @ £11.99 inc VAT
Solid VESA mount. Designed specifically for the Sapphire range of Mini PC's for mounted to the rear of any VESA compatible monitor.
Only £11.99 inc VAT.
ORDER NOW
1 x HDMI Port
2 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
CD Driver
ORDER NOW
1024 KB CPU Cache
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
CD Driver
ORDER NOW
1024 KB CPU Cache
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
CD Driver
ORDER NOW
ORDER NOW
