Sapphire PURE Advantage CrossFire power help!?
25 Sep 2005
Kent, UK
I have just bought this board from OcUK :cool: (the 2nd one down) and after finishing installing all the components, i came round to connecting the power connecter into the board i noticed that the power lead from the PSU has 2x12 rows of pins and on the board there is only a connecter for 2x10 pins. :(
Does this mean i have an incompatable PSU or is there something obvious that i am missing or do i need a convertor :confused:
Someone Help!
Thanks for any response
On my mobo there is a 20 pin socket and when I got my new psu it was 24 pin but noticed that the end 4 clipped off so it was compatable with both 20 and 24 pin sockets.
if you don't mind abit of diy you could always just cut the last 4 pins off so it fits ;)
This is what DFI say about 20 pin ATX.
You may well get away with a 20 pin, but you have been warned so to speak.
EDIT: I read it backwards as in you have 24 on mobo etc :rolleyes:
Like...the E is the four pins you dont need.
attachment.php
