Sapphire X1950pro q...
4 Jan 2004
Nottingham
Just a quick Q about thePCI-E version of these...Do they have VIVO on them? or just bog standard TV-out?
I've sent OcUK and web note but they couldnt tell me, so if anyone has one, can you confirm which it has? :)
The sapphire 1950 pros dont carry vivo only tv out.
not that your missing much, the rage theatre 200 vivo processor is crap quality compared to recent tv capture cards, even cheap ones.
not helped by the fact that the t-200 driver hasnt worked right since cat 5.3 and no longer supported in latest ati multimedia centre. 9.8 last version that works). dscaler has been laid to rest as doesnt support many cards now 100% with the latest driver versions, although nero showtime and powercinema will work.
damn it almost sounds like a rant and its not ment to be ;)
if you mean AVIVO video processing, then that is supported.
oh yea its AVIVO mine has :D . could have sworn it has vivo aswell though...
hang on isnt avivo just advanced video in video out?
