- 5 Sep 2005
- Northern Ireland
A friend of mine had old negatives that his grandad (who has passed away) took back in the 1930's. He's been wanting to get them developed, but anywhere he has gone to has refused him saying that they dont have the correct size of holders for his negatives (I assume the standards have changed since then).
Now, I have a flatbed backlit scanner on my PC, which can print out photos from normal negatives, using a special holder, which basically equates to a bit of plastic that shields the light from seeping through around the negatives, but shines through them clearly, giving a clear scan.
I probably wont be able to fit his negatives in my scanner striaght off, but I was thinking if I just get a bit of 300gsm (thick) black card, and cut an appropiate sized hole in the card for the negative, I should be able to get a clear scan.
Is my thinking correct?
Also, is there any reason why I wouldnt want to put old old negatives in my scanner? They wont get ruined by the bright light that will be used to scan them will they? I just dont want to ruin his originals, and am not sure is there is some difference between negatives back then and negatives nowadays.
