Might be best to send the link to o.c and see what they say.
I am hoping one of them will read this post soon. I would like to know what the yellow highlight on HDTune means and why it has affected my F3 so much to have it installed. More to the point, why has my F3 lost all its performance even when the new drive isnt connected.
Just some rading i have done elsewhere
The Spin Retry Count is attribute which stores a total count of the spin start attempts to reach the fully operational speed (under the condition that the first attempt was unsuccessful). A decrease of this Spin Retry Count value is a sign of problems in the hard disk mechanical subsystem.
something indeed seems odd here, obviously oc would want you to run a quick diagnostic on it, but the evidence here is pretty solid.
Definately refer to this thread if you Webnote tech, and also could you run some tests of the drives when both plugged in alone?
I have referred them to this thread on the RMA/Technical Quieries areas. If you look at post 33 I did a test with the F3 solo and it still gave me issues that I did not have before.
I really dont know what to do now as my F3 seems to have issues with or without the new drive, but I am unsure why this has happened. Also I am unsure why the new drive is having issues in the first place. It has to be something to do with what is highlighted in yellow on HDTune in one of my previous posts.
It looks as though changing the drives sata ports to test speeds has had an adverse affect on the drive. the only explanation I can think of is driver signing from one port to the next due to potentially running the drives on 2 separate controllers. Ill speak with technical to see if they know of anything like this and if they dont I will have a look to see if it can be replicated some how.
I must be honest, I dont completely understand what you mean. If you think there is something I can try to help the situation, if you post it then I can see if I can do it.
Would you like me to post the steps I have taken so far so you can recreate the issue?
sweet deal AM
might have to upgrade my NAS to a pair of these over my current barracuda 1TB LP drives![]()
Swapping the SATA port on both drives has resulted with both drives no showing massive dips. As such going from ports 1 and 2 (as an example) to then 3 and 4 and re running tests and back again has some how caused the issue. How the issue has been caused of what the issue is though I could not tell you as I honestly do not know but as said, I will speak with technical to see if they have seen similar before and if they know what causes this.
The worry is that there has been some sort of unexpected feedback from the drive which has degraded your SATA ports. Can you test the disk on another controller or board. If that works the fear would be your MB has had it...
