Seasonic 600w M12 volts help...
21 Sep 2006
Are these volts ok?
+3.3v @ 3.34v
+5.0v @ 4.87v
+12.0v @ 11.84v
Or are these a little low?
And how long does it take thermal paste to settle? As my CPU seems to run hotter in my new Akasa Eclipse from a Silentium T2.
Thanks.
21 Aug 2006
Stafford
Are those readings from a program or measured with a multimeter.
I dont think its the paste that has to settle in. The two cases are vastly different in design and airflow path. Have u mounted the fan duct for the cpu?
Man of Honour
27 Sep 2004
Glasgow
The readings are fine in that they are all within the +-5% range that is considered acceptable but if you haven't checked with a multimeter it may be better to do so.
4 Nov 2004
Not Aberdeen
use a multimeter on a molex connector which will give you the +12V and +5V readings. Ignore the software
My corsair HX 520W is bang on the 3V, 5V, and 12V lines under load :D
21 Sep 2006
Thanks guys, and about my CPU temps, I'd thought it would be cooler in the Akasa with 2 fans rather than my T2 case. :confused:
It used to be at 33'c idle overclocked, right now it's 34'c idle standard.
21 Sep 2006
Can anyone please explain on how the temps get measured from this pic?
What's the difference in the CPU diode and CPU?
Picture taken from Everest. The CPU temp is same as the CPU on Asus Probe II, but what's the CPU diode?
Thanks.
CBP
CBP
12 Jul 2006
FYI (slightly off topic) but my load temp is 2 degrees warmer after fitting the M12-600 than with my old Hiper type-r 580.
