Stormex is probably a little overkill. The Tent thing, massive overkill. I have an Oxford Rainex which is great. Can't see it ripping and the heat resistant side does work.
gcaster said:Stormex is probably a little overkill. The Tent thing, massive overkill. I have an Oxford Rainex which is great. Can't see it ripping and the heat resistant side does work.
Its around the same price and I like overkill
Edit:
What phone holder would you recommend for the bike? It's mainly for GPS purpose, voice instructions aren't too great, never trust them...
What length is your almax3?
Mines two meters but that is because my ground anchor is under some racking so needs to reach 0.5m before getting to the bike so then pinch pin looks good.
I was wondering if it'd fit through my swing arm linkage/connection bolt holes.
I'm also not sure on the strength of the materials used if it's be easier to cut through than my chain/squire padlock
