AC and heating are only solutions to a problem that need not exist (or at least to a far less extent) if homes were built in a way to naturally stay temperate. For example heat exchange systems in a well sealed home with good insulation can keep temperatures reasonable all year round without wasting huge amounts of energy on heating or cooling (the heat given off by the people living in the house can be enough at times).
It just seems odd that we have all this technology available but loads of people still live in old draughty houses that they can't afford to heat, some new builds aren't always much better (last one I rented was freezing downstairs). We should able to keep a building at a constant (or pretty close) temperature rather than the extremes of too hot / too cold and the arguments over when to turn the heating on (do you set it for a couple of hours or leave it at a minimum temperature etc). Plus you have other downsides to AC / heating such as drying the air out and causing skin complaints.
Essentially I want to live in a cave.
