Sig help
27 Sep 2004
Nantwich
basically, could you post if you are getting a login to a review site, im experiencing some outsider only login problems and i cant seem to find the cure :(
I need to sort this out asap as it seems this is causing problems for more than just my sig hosting :(
*removed for now*
tia
Post it as an image in one of your posts rather than putting it in your sig. Once the problem is sorted, you can put it back in your sig then.
It causes havoc if it asks everyone who opens a thread with your posts in it to login.
right, rebooted my monowall and modem, still the same?
ocukrotatingsig.php
jdickerson said:
Could be coincidence, but I wasn't asked to login that time...
Thanks, anyone else confirm please?
*edit* Brilliant, thanks a ton guys :)
Seems dyndns didn't like the fact my router hadn't changed its dynamic ip for ages (stability seems to be a double edged sword in this case)
Can i put it back in my sig now?
Mods please close if i can.
Mikol said:
Must just be me then :( I've cleared my cache and pressed CTRL+F5. Odd.
what browser are you using?
have you tried a full cleanout?
gah, i didn't need to spent tonight fussing over dns problems. :(
