As topic suggests stuck between
Arctic Cooling Alpine 64 CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AR
and
Coolermaster Hyper TX 2 CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-024-CM
Going to be cooling a 3500+ 939, currently @ 60C on Stock Heatsink.
Trying to make my case as silent as possible, sounds like im siting next to a fracking jet engine... I have the stock heatsink on it & 620W Corsair PSU which is supposed to be quiet...but something is loud as a mofo inside, which I assume to be the heatsink!
Which would be the better one out of the two, will they come with the thermal pad on the bottom, or do i need to source some paste?
Thanks
and
Thanks
