Simple water cooling to beat Corsair H70
i've posted em before its not pretty lol, i prefer function over form.
got the chip 2nd hand from Greebo here..
http://forums.overclockers.co.uk/showthread.php?t=18190066&highlight=golden+q9650
When l built mine, no hassle at all, all l did was planed my H2o loop prier to building it. Just as easy as building a PC if not easier, had a H50 1st.
You can't beat a custom loop, yes it might be more exspensive, went from 5870 H2o cooled to a 470 the FC Block + Backplate cost £70, but the only thing l hear is my DVD-RW spin up > silence is golden.
OLDPHART - Don't you find that the Dual Bay Res/Pump is noisy? Mine is noisy in the pump itself and then it seems to vibrate on the panels of my case and makes the noise worse. Have you done anything to make yours quiet/prevent vibration?
