SKY+ remote control question
3 Dec 2006
Somewhere I shouldn't be!
Not sure if this is the right place to post this query, please move if needed Mr Moderators.... ;)
My father in law has brought a new remote control for his Sky+ box, it is a SKY+ remote control, the "proper one" as he called it.
I programmed it to operate his TOshiba LCD easily enough and that works fine.
The problem he is having is a slow response from the sky box or no response at all, my questions are:
Do you need to program the remote to operate the Sky+ box?
If yes to the above, could you point me in the direction of how to do it?
Should it work straight out of the box?
I have been to the Sky website and could not find what I was looking for.
Thanks in advance for any help/advice. :cool:
If its a direct replacement for a Sky+ remote then no it should all just *work*
The slowness, i've never heard of it happening because of a new remote, quite the opposite in fact - the new remotes on the old Pace boxes work much much faster - certainly made a difference to us.
Is it a *new* remote or a second hand one?
