After my previous thread in which the only reply I got was about needing the 1080ti for 4K I’m not really expecting much, but I’m glutton for punishment so here we go.
I’m doing this on the iPad so not going to have the usual basket on these spec me threads.
Water cooled:
https://www.overclockers.co.uk/giga...-am4-ddr4-mini-itx-motherboard-mb-55r-gi.html
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-39x-am.html
https://www.overclockers.co.uk/cors...00mhz-dual-channel-kit-red-led-my-48e-cs.html
https://www.overclockers.co.uk/giga...mb-gddr5x-pci-express-graphics-gx-004-au.html
https://www.overclockers.co.uk/cors...ow-pc-case-black-cc-9011070-ww-ca-179-cs.html
https://www.overclockers.co.uk/sams...-3.0-x4-nvme-solid-state-drive-hd-22g-sa.html
https://www.overclockers.co.uk/micr...usb-pen-drive-retail-kw9-00017-sw-174-ms.html
https://www.overclockers.co.uk/xspc-raystorm-pro-water-block-amd-am4-black-wc-416-xs.html
Need advice on which radiators will fit in the case, tho I’m looking at 2x 240(the case can fit 2 with an itx mb or just the one with a matx from what I’ve read), looking at
https://www.overclockers.co.uk/xspc-rx240-dual-fan-radiator-v3-wc-295-xs.html X2
What’s the current pump/Res of choice?
https://www.overclockers.co.uk/mayh...ooling-tubing-38-12-13-10mm-1m-wc-115-mh.html 1m going to be enough?
https://www.overclockers.co.uk/mons...center-compression-fitting-red-wc-064-mo.html x6 I (already have 4 from a previous build so will be 10 total)
https://www.overclockers.co.uk/mayhems-pastel-red-coolant-1l-wc-060-mh.html
I have a Coolermaster RM850 PSU from 10 years ago, not sure if it’ll fit in the case
~£2200 before pump/Res and fans + psu if needed.
AIO:
My basket at Overclockers UK:
can cut it back changing the case and fans
With the new ryzens out in April going to wait and see how they do, however the case, cooling etc should be the same
Water cooled:
AIO:
- 1 x Gigabyte GA-AB350M-Gaming 3 AMD B350 (Socket AM4) DDR4 Micro ATX Motherboard= £72.95
- 1 x AMD Ryzen 7 Eight Core 1700 3.70GHz (Socket AM4) Processor - Retail= £248.99
- 1 x Samsung 960 EVO Polaris 250GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive= £128.99
- 1 x Seasonic Focus Plus 650W 80 Plus Platinum Modular Power Supply= £112.99
- 1 x Microsoft Windows 10 32/64-Bit - USB Pen Drive - Retail (KW9-00017)= £104.99
- 1 x Corsair Vengeance RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Memory Kit (CMR16GX4M2C32= £218.99
- 1 x NZXT H400i Micro-ATX Gaming Case - Black/Red Tempered Glass= £149.99
- 1 x NZXT Aer RGB120 Series 120mm Fan= £25.99
- 1 x NZXT Aer RGB140 Dual 140mm Fan + HUE controller= £78.95
- 1 x NZXT Kraken X62 AIO Water Cooling Unit - 280mm= £139.99
- 1 x MSI GeForce GTX 1080Ti Gaming X 11264MB GDDR5X PCI-Express Graphics Card= £949.99
