I've spent the day looking at this and I agree with most people that I'm not a fan of having them on the front door of a normal place. I can see the benefit in the case of access control where you need to grant and revoke permissions, such as a rental property or air bnb, but not a fan of them for home, or at least front door.
The use case for me is an accessibility issue, and having the unit able to perform the motorised lock rotation for someone that can't manage it easily. It seems some of these just use bluetooth or an app to authorise the user, but then you still have to manually turn the handle. I want something that authorises and rotates with a motor. Actually, I'm not even fussed about the authorisation, I just wanted a motorised lock as it's internal only.
I ended up coming across the
Ultion Smart, which it turns out is just the
Danalock attached to their handle and cylinder.
So then I looked at just getting the Danalock on it's own, but their shop is no longer live and people are
complaining about them on Trustpilot, it seems they've been very quiet on socials the last couple of years too, so perhaps it's a dying product? Weird if Ultion are stilling selling them.
It seems Ultion are now
pushing their
Nuki integration too. So I looked at that. Which looks much better supported, but doesn't quite fit where I need to mount it.
Then I came across this brand mentioned in a comment somewhere called
Tedee and it looks great, it's from a Polish teamup of a home door and lock company called
Garda, and a local software development studio and the Tedde product and app looks really polished.
It's also much smaller than the Nuki. Nearly all the reviews and vids are in German and Polish, so doesn't seem to popular here yet. I think I might give it a punt as it fits my weird use case requirements perfectly, and at least the company seem active,
reviews are good and the app looks polished.
You can also add it to your existing cylinder lock with an adapter, or buy a modular cylinder and adjust to your door type, perfect for UK cylinder locks.
