1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Smart Meter - worth changing to?
Discussion in 'Home and Garden' started by Dyson, Jun 1, 2018.
  1. ThriceNightly
    Wise Guy
    It really annoys me listening to the current range of radio commercials enticing the public to sign to a smart meter by claiming the amount of energy /money customers are going to save by having one. When in fact the cost of installing them is ultimately going to be passed onto the customers via higher bills.
    I still have my eon energy monitor (sensor clipped onto rising main) but despite the initial novelty value I unplugged it it as its really down to common sense once you understand how many watts a device uses. also you have to plug the energy monitor in...which uses electricity!
    Thanks that''s interesting information. Using Outfox as an example of a smaller supplier fairly new to the market, they currently purchase wholesale from wind farm energy producer Orsted. Would you say wind energy is less susceptible to market changes as gas/ coal?
  2. BigBoy
    I work for EDF as a Metering Engineer, and I can say for sure that all SMETS1 meters will NOT be added or upgraded to the SMETS2 system when it eventually goes live. This is because the Government who own the DCC have decided that "all meters not ORIGINALLY SMETS2 are there for not capable of being controlled by the DCC" (exact wording from the government whitepaper we all got sent at work). 99% of this thinking is because the DCC wont be able top claim the rental/tax from the coms hub.
    The main difference between SMETS1 and 2 is the communications hub on the top of the meter will be owned and operated by the DCC (when they eventually get around to producing something looking like a working company) the Energy Provider (EDF in my case) then owns the meter and pays a rental/tax for the communications hub. So it does not mater what make/brand the meter is its the coms hub that makes it smart.
    After installing several hundred meters in recent months you would be surprised to see how many people could not give too hoots how much electric they use. But after being shown how to use the smart system they soon become very interested in how much it costs to run things (like having a tumble dryer going flat out all summer when a perfectly usable washing line is available). Honestly the public have no common sense!
    Hacking is the governments biggest worry and partly why the DCC is taking so long to set up. The DCC will hold data on every house hold in every part of the UK even if you do not have a smart meter, all your reading will be sent there so when you do want to switch supplier it will be "easier" because the already have all the information needed. Also once the DCC is in operation ANY supplier change will involve you HAVING to have a smart meter even if you dont want one. All this is currently being brushed under the carpet by government as quietly as possible.
    I would link the whitepaper but I quite like my job and as its currently covered by a NDA I've probably said too much already....
    Any questions then please fire away!
  3. npinn001
    Gangster
    So is it best to wait then in the hope of getting the second gen?
  4. Psycho Sonny
    Caporegime
    if you have solar the last thing you want is a smart meter.
    when you aren't using all the solar. your old meter goes backwards. essentially meaning you are getting paid the market rate for it rather than the 3p they usually give you for it.
  5. andicole0
    Your solar panel installation should have included a meter check and change as necessary. If you have one going backwards you could be in for a retrospective charge.
    Most suppliers now have solar compatible smart meters.
    I can see no reason to avoid a smart meter as you will be forced to have one sooner or later. You still need to be aware of your usage and any anomolies so there is no need to be scared of them.
    Andi.
  6. Pottsey
    Mobster
    The reason to avoid them is they offer zero benefits at least to some of us and have drawbacks. For example yet another device on wireless is more interference and crowded wireless which is bad. All I see from smart meters is wasted time and hassle for zero benefits and being more complicated devices they are more likely to go wrong.
  7. sovietspybob
    Wise Guy
    As we only built our house in 2015 we've got a digital meter so no ability to 'store on the grid' like you could with old ones.
  8. MichaelAwkward
    Mobster
    As opposed to how many new mobile phones are bought every day? I can't wait to not have to take my readings every month. Sometimes I forget, sometimes I can't be bothered, one less thing to worry about.
    SMETS1 vs SMETS2 is a separate issue, but in principle smart meters that are centrally accessible and require no user input are a step in the right direction. I'll be over the moon when estimated readings are a thing of the past.
  9. flea.rider
    Gangster
    got a pay as you go .. £80 a month well £20 a week yr in yr out which is fine ...don't need a smart meter to tell me that
  10. ahar
    Gangster
    My smart gas meter broke and was replaced last week with a dumb one as that was all the engineer had in their van !
    I worked on the DCC procurement run by DECC - it looked like a bad idea then and it still does to me now!
  11. Pottsey
    Mobster
    Other people’s new mobile phones don’t have any impact on the internal signal of your home, while the smart meters can interfere. As for not taking meter readings last time I looked I still have to take monthly meter readings even if I get a smart meter due to solar panels so just what is the point or benefit?
  12. andicole0
    I have solar and only take FiT readings every 3 months. No need to take gas and leccy readings.
    Andi.
  13. Pottsey
    Mobster
    But its not really saving any time. It takes all of a few seconds to write down the leccy readings at the same time I do FiT at least in my case they are right next to each other. I just do not see the benefit of a smart meter when I still have to take a reading and submit it. Its hardly saving any time or offering any other benefit.
  14. andicole0
    Just think about what you've said, my FiT meter is inside my other meters are outside and not next to each other. The Smart meter saves me time, maybe not you but I don't really care about your time. There are benefits, however small you think they are. It also stops estimates and for many people this is a huge benefit. Just think of those who are less capable than you.
    Andi.
  15. Pottsey
    Mobster
    Yes there are benefits for some people. You said you see no reason to not get a smart meter. All I was doing is pointing out that there are reasons to not get one like they can slow down your other home wireless devices. Not only are there disadvantages at times, for some people like myself they offer no real benefit. For other people they are even more inaccurate and worse then old meters. I have seen people get shock bills due to smart meters not reporting accurately or enough and so they ended up with worse estimates.
  16. BigBoy
    Its up to you, until the DCC is operational SMETS2 is not offered
    Smart meters and Solar have worked side by side for years in industry why would there be an issue now? The reverse energy you speak of makes no difference to the reading on your meter...
    This
    Wrong, the Zigbee network they use is similar to bluetooth, they dont go near your wifi or any other network in your house, and as for interference dont be silly...
    never been such a thing
    Nope! see above smart meters use a mobile phone sim card and no way impact on any existing systems for the south of the country (basically midlands down) its Telefonica i.e O2 (for SMETS2) running the network back end, for SMETS1 they use a roaming sim so can use any network or strongest signal, the also only use the 2g network so the one that no one uses anymore as 3G/4g and soon 5g will take over.
  17. Psycho Sonny
    Caporegime
    How does the meter going backwards make no difference to the reading on the meter?
    It effectively means that I can use energy that I have produced whenever I want rather than when it is being produced.
    With a smart meter I need to use it there and then or it goes to the grid where I get paid 3p for it then have to buy it back for 13p.
    So I would be screwing myself by getting a smart meter.
  18. rainbowGuy
    as soon as i posted i saw that but to me it looked like a flat membership, didnt see anything saying its based on usage.. and 8£ is a lot and is more expensive than the current 10-12p standing charge I pay each day.. so I am confused they said they can still save me money when i inputted my usage data :s
  19. Psycho Sonny
    Caporegime
    it will obviously suit bigger homes and bigger households, those with electric showers and electric heating, etc.
  20. jpaul
    Mobster
    they use the same frequencies as bluetooth/wifi https://www.link-labs.com/blog/bluetooth-zigbee-comparison and have 10x more powerful transmitter 300m range !
    and apparently ping every 8 seconds ... so, if I was using blue-tooth headphones a lot say, I might be concerned
    I have very poor 2g network reception (does not work in the house !), I don't know if that precludes a smart meter ?
    but, I suspect meter wil communicate via zigbee mesh with other meters that have a better 2g ?
    edit - saw some answers
