We moved to our new to us bungalow, at the end of November. After lots of fixing and getting things sorted, I am now looking at getting a smart thermostat.
Currently, the house has an older system boiler setup. It is a Worcester boiler, estimated to be about 12-15 years old, and a hot water tank In the airing cupboard.
It has a Sunvic Select 207xl controller underneath the boiler on the wall and a thermostat in the hallway.
Currently, it's setup to turn the hot water on in the morning and evening, and the heating is similar. The thermostat in the evening however doesn't seem to make a difference, and the heating seems to just keep blasting on and on, unless I turn it off at the controller.
I have a feeling, out first bill is going to be pretty nasty. I've looked at the settings on the controller and can't really see why it won't turn off via the thermostat in the evening. Also the thermostat dial doesn't seem accurate.
So im looking at getting a smart thermostat. Seemed to have narrowed it down to turn Tado X or Hive.
Id need hot water and heating control. I will upgrade the boiler to a combi at some point next year but I don't know when, so this is the best option to control it for now.
Which one do people recommend. Also, do I need a wireless or wired one? I was getting a little confused by this. Current thermostat is on the wall in the hallway and is wired.
