'Smoothing' Painted Walls Before Repainting
  • Thread starter Thread starter mjd
  • Start date Start date
mjd
mjd
Permabanned
21 Oct 2002
Llanelli, S.Wales
I have the unenviable task of painting our hall and landing in the next few months. With the bedrooms I went at the walls with an orbital sander and managed to get a reasonably smooth finish to the walls before painting.
The hall and landing seem to be a little different though. I have no idea what the previous owner used to paint them, but it seems to be everything from brush, to pad, to roller. The finish is awful due to the mixture of painting techniques and is at its worst in those areas that see direct sunlight.
I know skimming would probably solve the problem in one go, but the cost is making me think it may be worth having a go at tidying things up myself in the first instance.
Apart from sanding, are there any quick fixes I may have overlooked?
Hehe - There isn't a hint of gloss about the place apart from the door frames I have done myself already. The last owner just smothered the frames in undercoat and left it at that. No prep at all as far as I can tell. When I stripped a few of the frames back last year there must have been 5 or 6 layers of paint on there, with the original coat being green. :eek:
Looks like I have a few good months of prep ahead :)
Not used it myself however the other TouPret products I have used are really good. This maybe a option - Tou Pret PLANEO G UK there is a YouTube demo of it.
Not seen it online to buy however it is in good Decorator's suppliers.
Orbital sander is still your best bet. If needs be, go in with some very coarse paper, then up the grade sequentially.
I mean, in extreme cases you could take it back to plaster, but that will be a mark of overkill, and you'll have to put a first coat back on the plaster!
