So will the 9800gtx be backwards compatible regarding PCI-E 1.1/1.0 ?
Anyone know what the PCI Express version is on the Gigabyte P35C-DS3R is? It only has one slot, that's why I'm asking.
Cheers,
Blue.
P35 chipset supports 1.1. :)
As said, the speeds don't tell us which version they are, as 1.0 can go up to 16x the same as 1.1a does.
So no nForce4 board will be able to use a PCIE2.0 card? Or could the manufacturers have used another chip on the board to provide PCIE1.1?
As far as I know, the PCI express bus connects directly to the northbridge so if the chipset doesn't support it, it most likely means the board won't. But I'm not 100%
i cant find if the nforce 650i supports it (p5ne sli). its so hard to find a list on the net which simply details the pci express formats on the boards.
this is absolutely ******* ******** for a fact, I have a badaxe 1 (975x chipset) and was going to buy a badaxe 2 for the higher fsb and even that does'nt have pci-e 1.1 ARGHHHHHHHHHHHHHHHHHHHHHHHHHH ffs, so why if pci-e 1.0 can run @ 16x the same as pci-e 1.1 why on earth can it not work with the 9800gtx ?
So.
965p is supported by pci-e 1.1
975x isnt supported by pci-e 1.1
p35 is supported by pci-e 1.1
If thats right, my GA_965p_DQ6 rev 3.3 should support pci-e 1.1, correct me if im mistaken.
Whats the bet the GFX card manefaturers release a PCIE 1.0 version of the GTX... if there's money to be made it will probably happen.
