Just a quick one if anyone knows anything about solar charging...
If I want to use two solar chargers to top up a battery do I simply just wire then to the battery in the same manner? (+) to (+) and (-) to (-) ?
The bigger picture is I've got a lot of kits im building and will be setting up and I want to power them off a 12v lead acid battery but from what someone else has worked out for me is that the 1.5watt charger prob wont do a good enough job to keep it from goin flat.
Any help would be great.
Thanks,
Soogs~
Thanks,
Soogs~
