Solar panel production figures
Just checked had a 9.9 kW peak afterwards at 2:40pm
I suspect you actually peak a lot higher, unless you can see second by second data you likely miss most peaks.
My system constantly monitors for the highest peak value, but if I look on the graphs which only shows the value every 60 seconds they often don't show as high.
Yes you're most likely correct. I picked those up at work with quite long polling intervals - home is every 10 seconds.
Back to today,'s generation 31.5 kWh surprisingly decent with all the rain.
200kwh is in sight vs the month target of 313kwh
Quite polar compared to 2024 when it took until the 23rd March to hit 200kwh
But the last 8 days of March 24 generated over 100kwh
FWIW 21st March is the midway point between winter and summer solstices so we move into the 6 highest months (by Solstice) generation in a weeks time basically.
29.3 kWh today, similar to the last few days. I did see a 9.9 kW peak today, though yesterday we very briefly hit 10,052 W just before lunch.
The cold weather has meant more heating, but we've actually managed to avoid too much heating in the day with the day sun and keeping warm overnight. Today the heating only used 1.7 kWh between 06:30 and 18:00 with an average indoor temperature of 20.8 C, which helps keeps direct solar export up.
A very choppy day with lots of intermittent sun, resulted in a very slightly above average March day.
SolarEdge: 13 kWh
Garage: 12.32 kWh
North west roof: 10.83 kWh
House rear wall: 5.63 kWh
Peak power was 10.15 kW at 12:08
Total generated yesterday: 41.78 kWh
Total exported yesterday: 49.38 kWh
Total imported yesterday: 30.11 kWh
