This is an outrageous rate. Well done.I’m lucky enough to be fixed at 20p/3p until next September so the gold rush is not quite as urgent for us. If Eon go bust, we are probably all screwed.
I'm with Ovo not sure if they have a tariff like that.If you are going on Agile Export then you will be selling export at a higher rate kwh for kwh than you pay for gas, in which case a diverter is a false economy.
Also note that some eg the Eddi have a timer option which is useful for setting in winter if you have an off peak rate, when leccy may be cheaper than gas, but if that is the only reason for getting one then a timer switch would be much cheaper!
Welcome to come over. That's what I'm on still until next Sept.I vote we go plug stuff in there!
It wasn't that good at the time I signed up, it was still 25% higher than what I was paying the week before. At the time, it was slightly above the price cap but has no exit fees for 2 years. Back then no one envisaged Russia invading Ukraine and prices were expected to go back down.This is an outrageous rate. Well done.
Just signed up to Bulb, took 11 minutes, very easy to do, paying exactly the same as the capped rates I'm on now, but will mean when I finally get my battery I can switch to the EV tariff (no EV required), and with a bit of luck Octopus will buy out bulb.I had to call them, the number they gave me was 0300 30 30 635 (Mon - Fri 9am to 5pm)
Now all I need is for it to go well with electricians tomorrow then I can try my luck at ordering some gear.
Has anyone here navigated a situation like ours? I can't imagine it's uncommon. Would love to know what the decision was - stay and invest / invest but move a year or so later / stay and decide to weather the storm of the unknown.
