Solar panels and battery - any real world recommendations?
Back on sale, but about £100 dearer than previous.
Is this a good brand/company? How would warranty work buying from Ali Express?
Is it not worth paying the extra to go Fogster for example?
Is this a good brand/company? How would warranty work buy from Ali Express?
Not worth paying the extra to go Fogster for example?
It's a 5 year warranty, presumably via the ecoworthy website
Fogstar is 10 years iirc
has anyone had a system installed to work when there are power cuts?
i cant remember the last power cut we had but have been thinking about it. our installer i think said £1.5-£3k depending on what you have.
we have an install date of 16 Nov:
16 x 480w panels, 10k battery, 6k inverter
I've had a Solis system installed, which doesn't use a gateway, but instead has a dedicated output that continues to be powered in the event of a power loss.
It's slightly different in that it's only selected circuits that will continue to be powered, but you can choose what you want. I went with all the house lights, plus the sockets in the garage (as that's where I have my server/network gear (so we'd still have wifi/internet (assuming the in coming connection is on)), They're on a UPS, but this would extend the operational time to over a day, rather than 20-30 minutes. And our spare fridge/freezer & freezer).
It cost me £300 more to have that installed, as an earth rod needed to be installed, and an extra CU for those circuits, but no extra unit.
I have a Sigenstor system and the Gateway was £1,400 more, I actually think this is reasonable as it must be quite a lot of work to install, it’s a full house backup system.
I did not get as I have not had very many power cuts in my area, I think maybe 1 in 10 years but I would not hestitate to get if I have more frequent power cuts.
I was quoted from £450 -£1200, didn't get it done in the end, think that was a mistake now.
Cost me £300 for my solax auto gateway (matebox upgrade from basic to advanced model), was half price as I had my system installed when there were shortages (2022) and my original planned system was out of stock close to my install date.
A huge shipment of the later/higher spec models turned up so the installer offered to split the difference.
By default the solax inverter could offer a couple of circuits that would be powered in the event of a powercut.
Its not a lot when your talking multiyear payback IMO.
Also, in normal times the gain is likely to be low. (Was fun when we had a powercut and stayed powered whilst the local facebook group was in meltdown about the power cut)
Its unusual times that may be when its worth it, such as should Russia increase the dodgy stuff towards infrastructure, should there be a supply issue to the gas power plants etc., or the Dailymail get their rolling power cuts they have been fearmongering over for years
At that point I bet those with it would consider it well worth every penny many times over because getting it installed at that point would be a nightmare and price gouged to hell.
The other consideration for me was I think the Sigenergy gateway is quite large, now I should point out I have never actually seen one in real life, but I have seen in photos next to Sigenstor systems and they look huge, it certainly would not fit under my stairs where my mains comes in.
Also in my opinion versus a standalone mains power bank I think it’s cheap to have a full house system.
If it’s in an external wall, you could have it installed on the outside - it wouldn’t be too much additional work compared to inside next to the meter.
The other side of the wall under the stairs is the garage, that’s where the batteries are, I could put the gateway on the wall above the inverter/battery stack but I have a plan……
We are hoping to do an extension, if we do the garage would come down and get rebuilt, when we do it I would like to bring a new mains cable in on the external wall, have the inverter/batteries and gateway on the external wall and just take a ‘thick’ cable back the consumer unit. No idea if that is possible/legal but seems sensible to me.
Happy at the moment so we shall see what happens.
Perfectly possible, my grid connection comes up under the stairs in the middle of of the house, I took two 3 core 25mm SWA cables out to the detached garage and back. So grid comes in, through DNO fuse, through meter, through a fused isolation switch, out to the garage, then returns back to the house consumer unit.
I should have used a five core cable, would have been easier/better but the electrician didn't mention that option, but I did get the 3 core cheap at an auction when a local electricians closed down.
Yeah, I just got the gateway as Tesla pretty much throw it in anyway as they need it for the load measurement and monitoring..
Last week on Thursday/Friday we had two power cuts whilst away, neighbours complaining on facebook, around 45 minutes or so each time and over the 2 days around 7 power cuts in total, all due to local infrastructure work (again!).. The Tesla Gateway seemed quick enough nothing reset when it switched over, but then it was powering the house at that time anyway, so no 'lag' as it ramped up.. why Tesla didn't make it a UPS grade style switchover is a shame..
Not been paying attention but I think our Sigenergy battery hasn't been charging overnight (cheaper rate) for a while now. I remember in our early months, the battery having charge when I woke up but it hasn't done in recent months. I have TOU profile set up to charge between 2-5am, have also tried removing and re-adding it. Looks like AI is turned off. Any suggestions?
Did you have solar as well, I forget, if so is that charging batteries at all?
Has there been an update, could have switched a setting off somewhere, like a "charge from grid" setting or something
(Eg on mine I can set a charging schedule but also need to have another toggle for charge from grid enabled)
Check the battery breaker if you dont have solar/its also not charging batts
Yeah we have solar and it charges the battery fine. I can't find any setting relating to charge from grid yet, there is an update waiting to be installed though.
Well thats good as you know the batteries are working then
Did it coincide with the clocks change maybe, could be some incorrect setting messing stuff up. May be worth tweaking the settings slightly to force some sort of refresh.
Yeah every manufacturer is different on settings which means its hard to help other than obvious stuff if you don't have the same manufacturer
That was my next lead, if so - would have been potentially 2 clock changes ago. I've updated and Gemini reckoned I needed to simplify my TOU schedule but the one I set up did work at the start. I've completely cleared and re-added, will check tonight so see if it's worked.
Mine's on AI mode and generally charges overnight now as there's less solar, and it favours export of any excess.
I did force it to into self consumption mode last night though, didn't realise it would be such a gloomy day today. So it's down to almost 20% now, might actually have to use some peak electricity for the first time in ages! Lesson learned.
