I'm gearing up to build a new PC with hard tubing. I've only used flexible tubing before.
I have a couple of questions about hard tubing and compression fittings. Specifically, how do I get it all put together where two components are really close?
I can understand that with a long run of tubing there's probably enough wiggle room to get it into the compression fittings and tightened up. But I'm going to have a pump and reservoir fairly close together. There is going to be a short (~5-10cm, probably) run of short tubing between them. Am I right in thinking that it's impossible to get the hard tube in both fittings with everything in place?
How do I deal with that sort of situation? Do I fit the tubing between the two components and then fit them into the case? Or is there some other trick?
(I guess this problem doesn't arise with Monsoon free centre fittings, but I've seen that some people don't like them because of the possibility of cracking and leaking. I've no idea if this is still a thing.)
