- 18 May 2010
With the above mentioned settings? How frustrating!
What incoming port do you have as default?
I had a lot of difficulty with getting my Yahoo mail set up as my default account in the standard email client, too.
Finally got it working with these settings, using IMAP:
Incoming: imap.mail.yahoo.com (port 143)
Outgoing: smtp.mobile.mail.yahoo.com (port 587)
Note that for some reason this only works very intermittently over wi-fi, but it works perfectly over HSDPA/G/3G/etc.
) - for username, you're just putting what comes before the @yahoo, right?
Oh. That's annoying. I don't know if your ports will be different on a different phone (I have a Galaxy S)? I just left mine at the defaults (which are the values I wrote in above). It might be you need to try those IMAP/SMTP settings with the default ports for your phone (i.e. the ones it has in when you first come onto the set up screen).
Another possibility (and I hate to ask...) - for username, you're just putting what comes before the @yahoo, right?
(I know, I know, but I've made the error of including the whole thing before now...)
Otherwise, I really don't know. I fiddled around with my settings for ages before I got these to work, and even now it won't work half the time if I have wi-fi switched on. So it's not as if I actually really know what I'm doing!![]()
Yes its extremely annoying! I've been messing for two days now!
I've changed my ports that many times I forgot what the default values are but I can reset it anyway. I'll try that next.
Yeah I dont include the @yahoo bit although I did at first!
I've now tried it with wifi and it still doesnt work, i'm at a loss with it now![]()
Can't find anything on IMAP but this is for POP from the Yahoo help pages:
Code:Incoming Mail (POP3) Server: pop.mail.yahoo.co.uk Outgoing Mail (SMTP) Server: smtp.mail.yahoo.co.uk (use authentication, optionally use port 587) Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com") Email Address: Your Yahoo! Mail address (e.g. [email protected]) Password: Your Yahoo! Mail password
