1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Sound card issue?
Discussion in 'Sound City' started by Sazzle29, Jan 6, 2018.
  1. Sazzle29
    Not sure if I can post this in here, but recently my computer has been saying there is no sound installed, but when I plug my headphones into my pc it works. Is it a card issue or something else?
  2. hondo
    Hitman
    I'm not 100% sure but almost. The sound from the front ports I believe comes from the motherboard, if you've a soundcard installed I'd be looking at the cards drivers
  3. Sazzle29
    Thanks, thought it might be. I checked into the drivers the other day, and I'm halfway to thinking it isn't supported anymore? It's a xonar dg card, but the website doesn't seem to let you download anything for it now. I uninstalled it, and it doesn't even seem to register with the computer that it is there.
  4. hondo
    Hitman
    OH no not Asus Xonar :eek:
    I've had a similar problem with a Xonar D2X + Windows 10. Asus Suppt needs to improve to be near on useless, coincidently I found a driver which works fine in a thread on here.
    Don't give up I'm sure you'll find something somewhere if you're persistent enough. :)
  5. EsaT
    Mobster
    Microsoft might have also broken alias updated something in Windows.:p
    Considering Asus has dumped support of even lot newer cards and recently even lot more expensive ones wouldn't be surprise if they ended support for such old PCI card.
    You could try UniXonar driver
    http://maxedtech.com/asus-xonar-unified-drivers/
  6. V F
    Capodecina
    Why?
  7. hondo
    Hitman
  8. EsaT
    Mobster
  9. V F
    Capodecina
    Sometimes I wonder where soundcards are going on the PC.
  10. Sazzle29
    So any suggestions for a decent mid range sound card? I've tried installing drivers i found on other threads, but installation gives up on me....card must have died :(
  11. V F
    Capodecina
    Is there a lot of these Asus cards dying a lot recently? I’ve seen people discussing this since the 1709 update on Ryzen systems and sound cards breaking. Hmm...
  12. Sazzle29
    From what I can gather, since the last windows 10 update there is now a code 52 error. Something to do with digital sigining of drivers. No idea what to do about this!
  13. Pistov
    Not trying to teach your gran how to suck eggs or something, but have you checked to see that the card hasn't simply popped out it's slot a bit? I've had this happen with cards a few times after installing upgrades and stuff, or sometimes even just changes in temperature can cause it to happen, and I usually pull my hair out looking for a solution before I realise it was something as simple as that.
  14. Sazzle29
    Yep, that was the first thing I did. Reseated everything and then looked at drivers etc.
  15. Pocah
    Gangster
    This is going to sound really stupid but have you tried changing the install folder? I found for some strange reason that Asus audio stuff often will not install to odd level folders.
Share This Page
