Spec me 3 office machines to run general purpose tasks including SAGE200
I think you'll find for bottom end it's difficult to beat the big players for cost, that's their forte, which in conjunction with the inherent support, let alone the testing they undertake it's not worth the effort to build yourself for business.
Plus the buck will stop at you if/when something fails, buy off the shelf and save yourself the hassle, and probably some money.
If the HQ has servers does it have IT support? At a company I used to work for one of the remote depots decided to upgrade their own PCs. The first we new was when we needed to go there to deal with a reported problem. The political fallout wasn't pretty.
Having discussed with my boss further about these 3 machines, he has concluded that they won't be connected to any server or HQ and will run standalone. Apparently we have in house support aswel so that's sorted. All i need now is 3 basic office machines for Sub £500 inc monitor, mouse and keyboard.
Bacon i have had a look at your spec and it's really good, i've taken one of the hard drives out though to minimise cost. Would you recommend anything else?
is space an issue?
im not sure how the office is setup but performance wise there be no difference to an itx mounted on the back of the screen
Mei, you would have loose cables, noise, dust, damage issues etc.
Revised spec if you can afford it.
YOUR BASKET
1 x Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-04649) £119.99
1 x Iiyama ProLite E2278HD 22" Widescreen LED Monitor - Black £109.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) £99.98
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £95.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £84.98
1 x Intel 330 Series 60GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £53.99
1 x Seasonic G series 350w '80 Plus Gold' Power Supply £46.99
1 x Fractal Design Core 1000 Midi Tower Case - Black £32.99
1 x OcUK Value 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £26.99
1 x Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £702.38 (includes shipping : £13.75).
The monitor is bigger with a 3 year on site warranty.
SSD for OS and applications for quicker load times.
Reliable PSU - currently pre-order so worth asking OcUK when they will be in!
PS. This leaves £30 of your choosing for mouse and keyboard.
YOUR BASKET
This is also a very good spec however as mentioned in my previous post, the boss has lowered the budget to sub £500 now including everything! Can you revise the spec again please? thanks
just giving you some options
hooks on the back of the screen then just 1 hdmi cable, nothing under the desk
YOUR BASKET
1 x BenQ GW2450HM 24" Widescreen LED Professional Monitor - Black £137.99
1 x Seagate Momentus XT 750GB Hybrid SATA-II 2.5" 7200RPM 32MB £107.99
1 x Antec ISK110 MiniITX Vesa Mountable Case - Black/Silver with 90W Power Supply £89.99
1 x Asus P8H61-I Intel H61 (Socket 1155) DDR3 Mini ITX Motherboard £63.98
1 x Intel Pentium G840 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail £56.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £23.99
Total : £495.02 (includes shipping : £11.75).
id tell him tho sub £500 you be skimping on the screen/keyboard and then i wouldnt want to work in his office^^
YOUR BASKET
Hows the motherboard suppose to fit in the case? dremel?:p
