Spec me a Projector
25 Sep 2011
Afternoon,
After a cheapish nothing crazy fancy short throw projector for the bedroom. (would like to keep it under £300 if possible?)
It'll be a distance of around 2.5meters (what size projection should I expect?).
A couple HDMI's in would be nice.
Other then that I know virtually nought about them, so any insight or tips would be appreciated.
Amazon would be great too, as have a couple vouchers kicking about.
Thanks!
Personally Id buy from richer sounds as they often include six year warranty or if not its ten percent of cost. Try avforums.com think they have a calculator for image size with various models of pj, my optoma hd50 is about 3 metres away and i get a 106" image not on full zoom.
Just looked on rs and the optoma h183x is £299 has a throw ratio of 1.55-1.73:1 so would throw a screen size of 1.61 to 1.44
Ive just bought a X152h which are on offer on the rainforest for around your budget. Not opened it yet will be setting up tonight. Seems a good deal for that price.
