Spec me a TV < £300
28 Mar 2016
Hello!
My tele has just died and I'll need to replace it pretty sharpish. I dont think the family will like to be without one for too long :p
I'm looking for something in the range of 37-40", less than £300 ideally more around the £200 mark.
I dont need (wouldnt use) built in smart TV stuff, I'll just need 3x HDMI and full HD I think. I dont have any external speakers so if the TVs speakers are better than trash all the better :p
Are there any recommended TVs that would fit my criteria? I'd rather not just go to Currys and see what they have.
Thanks for your help.
£200 for a 40" TV you won't get much for that i doubt even with the non smart features. if you push it to £330 you might get a 40" Samsung H6400 which i would deffo recommend
Yeah I didn't think I'd get under £200 really but I had been looking at the 40" Samsung H6400. Slightly over what I wanted to pay but the amount it'll get used it wont be wasted money at all.
Do you have the H6400 Nicknack?
That LG looks good Clov!s, but I don't think I could fit a 43" in to the TV alcove :mad:
Yes i have the 40" and 48" H6400 Great TV's and looking to get the 32" from argos for £269 for the kitchen. You won't be disappointed with the 40". Be keeping these for next couple years. And then see where we are with OLED
