I would go for a Cowon D2, but I'm not so sure about using the internal memory + SD cards. Need something portable-ish, and not an ipod or creative (from my experience ipods aren't the best music quality and creative players are sloooooow.)
That narrows it down a bit. Which is the smallest of these players and what size SD cards are available? Doesn't using SD cards make file transfer slower?
Great, thanks. I'll look into buying a 4GB D2 with an 8GB SD card,as it ends up cheaper than buying the 8GB model.
How is the touchscreen on these? Hoping it's not very fiddly.
