Ok, it's been a while but it sounds like my BeQuiet AIO system has a bit of pump noise - I tried topping up but it keeps coming back, so I'm thinking of takng the opportunity to do an upgrade.
My current system/specs are here: https://forums.overclockers.co.uk/threads/family-and-heat-friendly-matx-build.18774056/
I'm considering a pump/res combo and CPU block initially, with enough overhead to add the GPU in if a block comes on offer - there's no need right now as temps are very good as-is.
I'd like an Aura-compatible RGB res and block but there's not too much space on the window side of the case as you can see here (the rad is now the other way up), so it may have to go in the PSU side unless it fits along the bottom. If it's not going to be visible then no need for RGB for the res:
So, recommendations please. I'm hoping to use the BeQuiet rad as it fits nicely with a little room for a GPU upgrade as and when and has screw fittings.
