Spraying plastic case parts.
Caporegime
14 Dec 2005
armoy, n. ireland
Ive got an old akasa eclipse 62 sitting unused, fancy painting the exterior of it, (thinking metallic blue). Would it be possible to spray paint the front plastic fascia to blend in with the panels.
It should be fine - just check the Skeleton mods for plastic painting tips. Only thing I can think of is the shades might come out marginally different, but it depends on how well you do the job, and how much paint you lay down.
