Sprocket carrier bearing for CBR600 F3
4 May 2009
Southampton
Hopefully there are one or two that know the answer to this.
As I'm replacing the cush drive rubbers and I figured I'd replace the sprocket carrier bearing at the same time. However I don't know if I need one set of bearings or two (like one for each side).
Does anyone know? Google has not been forth coming on this one
Just one
If they don't feel notchy then they shouldn't need replacing?
You have two wheel bearings and one sprocket carrier bearing,each can be bought separately
Just one
It was more for the sake of a few quid I might as well do it while the wheel is off and save me coming back to it at a later date
I would definitely recommend you doing it, mine was fine when I changed a tyre last year, no problems in the MOT then two weeks later I change my back tyre and the bearing is knackered, make sure you get one thats sealed, will probably outlast the bike then :p
Yeah I picked up a 'double sealed' bearing. Hopefully will be here today with the rest of the parts for her.
Parts:
exhaust gaskets
very high temp paint
head studs and bolts
rear brake disk
rear brake pads
cush drive rubbers
chain and sprockets
