Caporegime
Tether your phone to it?
see above. (or below as it now is)
I tried hotspotting from a Galaxy S on hols too, and it didn't work. Like you said, something Steam needs seems to be blocked by most mobile networks.
What worked for me was disabling all NICs in windows - this allowed Steam into off-line mode.
Nate
That's not entirely accurate.
As long as the game you want to play is up to date and has been run at least once it'll work.
Steam client updates won't effect it unless you haven't restarted steam since you applied one. As long as you've run it once it'll start in offline mode.
Uninstalled games, or partially downloaded games won't effect offline mode, you just won't be able to use those particular games.
One thing I did find tho quite a few (tho not all) games will work fine in singleplayer/offline mode if you start steam up and leave it at the error then try and launch the game from its own folder (the application "sees" steam "running" and continues).
I can honestly say i've never had a problem with Steam Offline mode.
When going to LANs and what not, the night before i'll fire up steam, make sure i've ran all the games I intend to play the next day, then shutdown.
At the LAN i'll turn on my PC, launch steam, it pops up 'cant connect, do you want to play in offline mode', I press yes, and that's it.
It is entirely accurate - as I said I'm not sure on partially downloaded games - but any pending update (via steam including paused ones) on any game in your library including steam updates that haven't been applied via a restart will prevent you starting in offline mode without an internet connection.
