aahh sweet thats good to know... is it even fine with a bit of vigorous sequential shifting?I have a DFP which i THINK is similar in size. If this is in fact the case, then 25cm will be plenty, just got my tape measure out and everything.
doesnt look sturdy enough for force feedbackI bought the "wonder table" from halfcost.co.uk and does a pretty good job for me - adjustable height, folds away flat, and only costs £1.99!!!!!!!
totally appreciate what you're saying, but we just don't have the space for a full setup like that...Think your missing part of the point regards a seat/frame.
Yes it can be a pain in the backside dismantling etc however....
Its all about comfort and being able to concentrate without distraction that allows you to enjoy the racing games. On a good racing frame you could sit for 3 or more hours with no major aches, thats what you need to achieve.
If you arnt comfortable and eventually find your giving yourself a bad back this will put you off using just a table of sorts so you still wont benifit.
Look into ebay for proper bucket seats from as little as about £60 and consider your own d.i.y frame thingy that will allow easy dismantling and using the seat as a chair on its own perhaps?
naah, the seat is normally further back than that, and i have my arms and knees only slightly bent so it all fits fine...your knees dont hit the table? looks like a tight fit
how does it perform?
