Stick with HP N54L or DIY build
3 Mar 2010
Just a quick question, I have a HP microserver N54L which consists of an SSD for OS (win 7) 2 x 2tb in RAID 1 a 2tb as back up and a 3tb as back plus ive got 2 x 3tb external hard drive also used for back up.
Now im running out of space to add more hard drives as im running out of space for my photos. Now i can get bigger drives or was thinking about using my old htpc (amd 5300 fm2, msi matx board, fractal r2) as a server just upgrading the ram. The case gives me the flexiability of adding more drives.
I use it mainly as a plex server for my movies, pics, home videos and music.
So should i stick with the microserver and getting bigger hdds or using the parts i have and just add the extra hdds i havd laying about??
You could even get 8 in if you tried. 4 in normal bays and then 4 x 2.5" drives in the ODD bay. Obviously you need the right addin PCI card to give you the extra connections though.
Me I have 5 drives in my N54L and then 2 x 5 bay DASs connected to it via e-sata.
You can actually fit 6 3.5 drives as I have done here
It's done using a bracket and the esata port so no pci card required. I also did the bios mod to get the full speed out of the ODD sata port.
Ignore the mess :o
Ah cool, nice one Uhtred, I need to get 6 x 3.5" drives in my Microserver but not looked at how I was going to do it yet but that looks spot on, where did you get the bracket?
I am going from a full ATX case NAS back into a Microserver but have 6 x WD Red's in there and a raid card to get into the N54L! :)
Mine was a NEXUS TECHNOLOGY DoubleTwin Hard Drive Mount which is quite difficult to get hold of. I found mine on the american bay.
I have been toying with a self build to replace my N54L but I never have due to the low power the n54l uses with 5 drives mine only pulls 60w :-)
Would love to hardware raid mine but the cards that fit the swap bays connection are around £150 - £300 :-)
Software raid is good if you stick to Microsoft versions or Linux
Replaced my N54l with a self-build based on a AMD5350 APU. Same TDP (25W) as the Turion in the N54L but 2 more cores, integrated GPU etc.. Doubt it draws any more power than the N54L and it cost me less than the N54L, even after cash back.
Ive decided to stick with the n54l as its just a nice compact system and it does exactly what i want and nlw i know i can add up to 6 drives its a no brainer
Never thought of the Low power AMD options, may have to look into that option in the future. ;)
Before i swapped out to a bigger server i had 9 drive in mine 4x2tb 3.5s in the bays, 4x 2.5 first (320gb then 2tb) in the 5.25 bay and a sshd mounted under the 5.25 in behind where the badge is. I only changed as I wanted to increase size of drives to 4tb after a couple died but it was fine like that for 3 + years. Was a N36l BTW, also had a r7 240 in there with a marvel sata card for more ports.
You crammed a lot in a small box
