Strange blurry icons and text issue
15 Mar 2006
Vancouver, BC
Ok I have a 9600Pro 128Mb on windows XP Pro 32bit with the latest Catakyst drivers and I am getting a very strange issue with my icons all being blurry, also the font is hard to read on some windows but not others. Before I installed the ATi drivers the picture was perfect when windows was using the generic VGA driver.
What can I do to fix this issue guys?
were there any other drivers on before?
have you tried any other drivers?
try running driver cleaner in safe mode and then redo them or try a diff set.
its always best to run driver cleaner before you put on ya gfx drivers unless its a fresh install of ya os.
from what ya say its a fresh install (Before I installed the ATi drivers the picture was perfect when windows was using the generic VGA driver) but running driver cleaner cant hurt and worth a try imo.
I have installed the drivers twice now and used driver cleaner to uninstall fully both times too, I still have the same issue. Where can I find older versions of the ATi drivers as this newest set are obviously no good.
Ok I have just realised that the S3 Savage gfx drivers were still installed, I have removed them and the ATi drivers and will try another fresh install, I hope it works.
Ok I have just realised that the S3 Savage gfx drivers were still installed, I have removed them and the ATi drivers and will try another fresh install, I hope it works. Nope :(
Nothing seems to fix this issue, I have even updated the bios out of desperation.
who make the card.
i had issues with using generic ati drivers from the ati wesite.
went onto the manufacturer of my card (HIS) and it runs perfect now
Ok so I tried everything including a fresh windows install and still it did not work. I decided to go out and buy a new ATi Radeon 9550, installed and it works fine. That means my $23 bargain Radeon 9600 was not such a bargain after all.
