Strange monitor effects ?
17 Jul 2010
Ive got a LG Flatron W2234S Monitor.
My problem is, in games, I see strange monitor effects such as thin white stripes going from up to down very fast, its hard to describe. im suspecting its refresh rate or something.
Im using a VGA to DVI connector with my GTX460, is that the problem ?
in Furmark aswell, I get a think rectangular black strpe going up and down.
Could someone help ?
try turning it on, in the in-game options and the graphic card driver control panel.
is this white line from top too bottom? or left too right?
is it a white line? or does it look like someone has run a pair of scissors through the screen?
Its from top to bottom, bottom to top sometimes.
Yes turning it on has seemed to fix it a bit, but its still there. and it seemed to reduce my FPS.
Its a faint white line.
Yeah ive just checked and everything is fine.
In furmark its a single black line going from top to bottom or stopping in the middle and going back to the top.
Sorry I was wrong all the time, its from bottom to top, not opposite.
Is the card going faulty ? Its new, all ive done with it is OC it a bit when I play games.
Yeah but guys even though when I turn V.Sync on it seems to help, the problem doesnt go away fully. in oblivion when I get a small stutter somewhere i would get those effects, but when its smooth, they are gone
