Hi all,
I'm after something rather particular to my needs, but I have to assume there is something out there which can do it..
Basically I want to be able to stream live VGA output from my PC to another room and a TV screen. Something which could use the cat5 already in place would be great, but anything that allows me to view whats going on on the PC screen on the TV at the same time would be ace.
Oh and sound is pretty much essential too.
Anyone got any experience with this, and can recommend any products/software/kit/magic spells which I could use?
Thanks.
FYI, PC vid card has two outputs (GF7950GX2) and the TV has about every plug known to man. I imagine the largest boundry would be the resolution differences between my standard desktop (1280x1024) and the max of the TV. But there must be something which converts it etc etc etc etc etc. Anyway, hope someone can help.
Thanks.
